Business Practices Mileage tracking Tips
How to Log Miles for a Tax Deduction (Without the December Panic)
Odometer reading on a car dashboard, showing accumulated miles from everyday work driving.
Most mileage advice on the internet assumes you’re choosing between apps.
But when people show up on Reddit in February, they’re usually not shopping. They’re panicking.
They’re staring at a tax organizer that asks for “business miles,” and all they have is a number from DoorDash/Uber/Amazon, a hazy memory of “I drove a lot,” and maybe an oil change receipt.
This post is the boring, practical part: how to log miles for a tax deduction in a way that (1) doesn’t miss trips and (2) is believable if you ever have to explain it.
What the IRS actually wants in a mileage log (and what people assume it wants)
A mileage log isn’t just “total miles for the year.” That’s the number everyone wants to jump to.
What you’re really building is a record with enough detail to answer basic questions later:
  • When did the trip happen?
  • Where did you go (start/end is usually enough)?
  • Why was it business?
  • How many miles were driven?
You don’t need to write a novel. You do need something that looks like a normal human record made close to the time of driving – not a spreadsheet you “reconstructed” the weekend before taxes.
The real reason people lose deductions: missing trips, not math
Most people don’t lose money because they calculated wrong.
They lose money because the log is incomplete.
Real-world scenario: You do gig deliveries and also run personal errands. You tell yourself you’ll track mileage “later” and keep a note in your phone. Two months in, you miss a week. Then you miss another. By December, you’re basically guessing – and guess what happens? You either:
  • under-claim (quietly losing deductions), or
  • over-claim (and now you’re nervous about audits because you know it’s fuzzy).
This is why “manual tracking” fails in practice: not because it’s hard, but because it relies on perfect memory during busy weeks.
GPS miles vs odometer miles vs “platform miles” (why they don’t match)
This mismatch is at the center of a lot of tax anxiety.
Here’s the reality:
  • Odometer miles are what your car actually drove.
  • GPS/app miles are what a phone thinks happened based on location pings, battery settings, and whether the app was awake.
  • Platform-reported miles (Uber, Instacart, etc.) are often only “engaged” miles or a specific portion of the trip (and sometimes the most tax-helpful part – like driving to the pickup – gets excluded).
So if your platform says 12,000 miles and your odometer says you drove 18,000 “work-ish” miles, that doesn’t automatically mean you’re doing something shady. It usually means the platform is counting a narrower definition.
The key is: pick a method you can explain and consistently support.
A dead-simple workflow that holds up at tax time
If you want the least stressful option, build your log around two layers:
1) A trip-by-trip log (the detail)
For each business trip, you want: date, start/end, purpose, and miles.
The purpose can be short: “deliveries,” “client meeting,” “hardware store for job,” “bank deposit,” etc.
2) A yearly “reasonableness” layer (the proof you were driving)
This is what calms audit anxiety because it makes your log make sense.
Do these three things:
  • Record your odometer at the start and end of the year (or at least a few anchor points: Jan 1, quarterly, Dec 31). A photo works.
  • Keep 2–3 supporting receipts that place your car in time (oil change, tires, inspection). You’re not proving every mile – just showing your year isn’t imaginary.
  • Separate commute/personal patterns in your own mind. If you have a day job and also do gig work, be clear about when “work driving” tends to happen.
This combo helps because if your trip log ever has gaps, your odometer anchors keep you honest.
Common mistake: trying to recreate a year of driving from memory (or bank statements)
The most common failure mode I see (and have personally lived through) is trying to backfill.
People try to rebuild mileage from:
  • credit card transactions (“I went to that store, so I must’ve driven…”)
  • calendar events
  • platform summaries
The problem isn’t that those sources are useless. It’s that they don’t naturally produce a clean mileage log with purpose + miles. Backfilling also tends to create suspiciously “smooth” numbers (the same miles every week, perfectly rounded totals). Real driving is messy.
If you’re already behind, it’s still worth salvaging what you can – but going forward, the goal is capture, then categorize (not the other way around).
Subtle insight: your log is a story – make it easy to believe
This is the part people don’t say out loud: a mileage log isn’t just data; it’s a narrative someone else can follow.
The log that feels believable usually has:
  • variation (some short trips, some long ones)
  • clear “why” (deliveries, client sites, supply runs)
  • consistent habits (you don’t magically stop driving for 6 weeks unless something happened)
One small habit that helps: add one extra word to the purpose.
Not “work.”
But “deliveries – dinner shift”, or “client – estimate,” or “supplies – plumbing job.”
That tiny detail is what makes a log feel like it was written in real time.
Install the MyCarTracks app and start tracking your mileage now
If you use an automatic tracker, set it up as if it’s going to fail once
Automatic tracking is how most busy drivers avoid missed trips – but you still want a “failsafe mindset.”
Two things I do because phones are unreliable in boring ways:
1) Check for missing days once a week (takes 2 minutes). If you wait until tax time, you won’t remember what happened on a random Tuesday in May.
2) Use odometer photos as guardrails. When your year-end odometer and your logged totals are wildly far apart, that’s your signal to investigate gaps now, not next April.
In practice, the most reliable approach is automatic tracking paired with a quick weekly review. Let the drives be captured passively, then spend a few minutes each week labeling business trips while everything is still fresh. The habit matters more than the tool.
If you take only one thing from this: the best mileage log is the one you’ll still trust in December. Build it so missing a week doesn’t turn into losing a deduction – or lying to yourself about what you drove.
